The storage temperature spec is -40C to 70C, and operating spec is -40 to +60C. It's really designed to be outside, where it can get air flow, but you should probably be fine mounting it as you're thinking of doing (people have done it this way before). If you're in a real hot climate, you may be able to heat soak it beyond these ranges. Anyway, there's all the data.
