I have an RV-6A that has about 7 degrees of panel tilt. Can an EFIS be adjusted for this tilt or do I need to buy a specific unit that has this panel tilt built in like you have to do with a mechanical gyro?
The EFIS-D10A can be adjusted for up to 30 degrees of panel tilt. Note that this question (along with a lot of other common ones) is answered in our FAQ.
http://dynonavionics.com/docs/FAQ_EFISD10A.html
To configure this in the EFIS, enter the onscreen menu system, press MORE > SETUP > PITCH. You can then increment or decrement the pitch adjust value until the horizon shows straight and level during normal flight attitude.
