I'm installing a D-10A into my airplane that already has a D100. The D-10A harness came with the standard 9-pin port wired in for updates. Do I need to use that 9-pin port, or can I remove the port and wire the three wires that go to it into the existing 9-pin port that goes to my D100? (I'm concerned most about the transmit line).
If that wiring scheme is OK, when I do updates, I figure I'll update only one unit at a time, and have the second unit off while the first is updated.
Is that the way to go, or do I:
1. Need to use both 9-pin ports...or...
2. Use one 9-pin port, but run the transmit line via a switch to select which unit gets updated.
Or does DSAB magically fix this and I can update either once they are networked?
A bit confused on this one, and can't find it in the install manual or previous threads. Thanks for the help!
Cheers,
Bob
Cheers,
Bob
