PC to EFIS D10 program?
Flyer4DV
I purchased an EFIS D10 a few years ago for installation in a homebuilt aircraft. The plane is now ready to fly, and I need to configure the D10. I recall seeing a program that I could load on my laptop to input the checklists, calibrate the compass, etc. I do not see the program available now. Did I miss it? Will the D10A program work? Do I need to upgrade to a D10A? If it matters - my D10 is a stand alone instrument, but is functioning as an encoder for a Microaire transponder.
Thanks,
Jerry
The same program is used for checklists on all units, including the EFIS-D10. Download the latest support program from here:
http://dynonavionics.com/docs/support_software_200710.html
To calibrate the compass on a D10, that's a separate program, from here:
http://dynonavionics.com/docs/support_software.html
Make sure you choose the right one, based on if you have an EDC or not.
Updating to a D10A is your choice. All the neat new stuff we have is for the D10A, and no updates will be done for the D10 anymore (unless they are safety related). If you do get a D10A, you'll need to install a encoder converter ($80) or a standalone transponder encoder.
