I am considering using pin 18 of the EMS to power these items:
-MANIFOLD PRESSURE SENSOR PN 100434-000 PIN C (POWER SOURCE)
-GRAND RAPIDS CURRENT SENSOR CS-02 BLUE WIRE (POWER SOURCE)
-WESTBERG FUEL CAPACITANCE PROBES POWER SOURCE (2 PROBES)
-FUEL COLLECTOR TANK LOW DISPLAY ON THE DYNON SCREEN (SIMPLE FLOAT SWITCH)
-DOOR OPEN ANNUNCIATION DISPLAY ON THE DYNON SCREEN (2 DOORS)
-ALTERNATE AIR DOOR OPEN DISPLAY ON THE DYNON SCREEN (MICROSWITCH ON DOOR)
Would the pin 18 have sufficient capability for these items?
The only real current consumers on the list would be the Manifold Pressure, Grand Rapids CS-02, and the Fuel Capacitance Probes.
The fuel probes are Westberg 0-5 VDC probes and the manual dose not specify how much power the sending units draw.
I assume that EMS pins used to produce an annunciation icon on the Dynon screen itself are miniscule power consumers way down in the millivolt range...
For the doors open indicators, I plan on using simple spring loaded microswitches that have contacts that are open when compressed and closed when sprung outward. The fuel float is a simple switch that is open when the float is up and closed when the float drops.
Thanks for your help!!!
