Pitch and VSI Seem To Be Jittery
Dynon101
I love flying!<br />
Hi again,
When flying it seems my VSI is really "jittery" meaning I think it is overly sensitive. I've flown other airplanes with EFIS and they do not seem to jump around as much as this VSI does.
My static indicator is a piper Cherokee type unit that has a heated pitot tube and a static port so at this point I do not think that the issue is rough air at the static port. I flew the airspeed changes test and the static was very close.
Is it coincidentally that my oil temp indication is also "jittery"?
Here is a copy of the Savvy chart for pitch and VSI.
THANKS for your advice!!!
  • PITCH AND VSI.pdf
This is probably coincidental. If oil temperature is jittery, I'd be looking at sensor connectivity first. As long as other readings are solid with SkyView, it's not likely to be a grounding issue. As for the other observances, can you send our support team a video so that we can see what you're seeing?
