I have an RV10 with Skyview Classic and a SV42T pitch. Software 15.4.7. AP had been working perfectly for 5 years until recently.
Pitch was showing slip and not holding attitude. Discovered that the shear screw was sheared so replaced it. Calibrated and tested fine - controls move smoothly and correctly to the corners. However, on the ground and in the air, pitch will not move correctly - slips and judders.
I disassembled the servo and could find no obvious fault (it’s well out of warranty and easy to do!). Refitted, recalibrated and tested, reloaded software - same result.
I’m stumped as to why it moves smoothly under test mode but not when I use the AP. I suspect a software issue. I see a “bug” mentioned in another thread describing similar symptoms. Could this be the problem?
