rvg8tor
The new matched hole kits have the elevator bell crank mount formed into the baggage floor ribs, they are not riveted on separately. The Dynon bracket is designed to replace the Van's bracket that gets riveted to the baggage floor ribs. You will have to do some work to get the brackets to fit with the new kits. I promised Dynon that I would post what I came up with to make the brackets fit. I will try to attach a PDF file that contains the 3 entries from my log, if you can't open it just go to my log site and the Dynon Pitch Servo has a separate category. It worked out really well even though it took some work to get it to fit. Maybe Dynon will be able to manufacture the brackets so they fit right out of the box.
Cheers
Mike
www.mykitlog.com/rvg8tor
Cheers
Mike
