PMag and RPM on a D180/120
putco
Hi All
I have a Pmag in my Lancair with a Superior io360 and a D180 with EMS120. When l select the pmag to check it, the RPM shoots to 3100 and never settles. The RPM l feel is out anyway, what pulse count should l have set in there?
My manifold pressure is wrong too, are these sensor issues or wiring?
GalinHdz
KSGJ/TJBQ
Hi All
The P-mag tach out  (pin 6) transmits 2 pulses per revolution so either set the EFIS to count 2 pulses per revolution or set the P-Mag to transmit 1 pulse per revolution. I also found that on my Skyview/EMS I had to use the enclosed 5.1v Zener Diode (between P-mag pin 6 and pin 1) to prevent the RPM indications from going haywire every once in a while.
An incorrect manifold pressure reading is normally caused by a misconfigured MAP sensor within the EMS settings.
:cool:
What are you seeing on manifold pressure? The leading cause of incorrect readings there is getting the wiring incorrect on the sensor. That leads to "pegged" values.
putco
Hi and thanks for the replies. I'm getting 14.2 unpowered at sea level and at runup not much more than about 16.
As DS said, you need to check the wiring  ;)  the connector on the MAP sensor actually has pins A, B & C shown on it as part of the moulding at manufacture, they can be hard to see as they are the same colour as the rest of the plastic.
Jake J
