Posted on Install Apr 04th, 5:51am - No response?
Graham711
Posted Apr 04th, 2008, 5:51am - No response as of 2pm EST 8th April
Hi!
I am in the process of connecting up the Dynon Jabiru 3300 Engine Kit supplied Sensors, upon installing the Current (GRT CS-01) Shunt and wiring it exactly as per the instructions, I get a Max Scale reading of +99 Amps - even though there circuit is only pulling 3 amps. The output from the shunt is OK at 1.6Mv. When I went into the setup today to double check everything, it strangely read correctly when I opted out of the setup mode - until I shut it down, now I am back to square one again with 99Amps reading. Oh.. the case to ground is reading 0 volts. And yes, it is a Dynon Harness Can anyone explain what is wrong here? There is only two sensors available in the setup - the second being the Hall Effect Type with an Off-Set adjustment.
Regards
Graham - Auzz
