"%" power is not displayed EMS D120
kulibin
Tell me what could be the problem. The fact is that I have assembled a scheme from EMs D120 and EFIS D100, I have an OAT sensor, the consumption of fuel and MAF, the O470 engine and the "%" power is not displayed. The display shows dashes.
In my experience installing about 8 sets of EFIS and EMC as well as several SYNTHETIC VISION systems this behavior is unclear. I ask to push on the right idea .... By the way the software of the extreme version
The display will show dashes on the ground. Are you seeing this in flight, or just while installing the system?
To have % power, we need:
MAP
RPM
OAT
FUEL FLOW
OIL PRESSURE
ALTITUDE (From D100 or GPS)
Do you have all of these in the system?
kulibin
MAP
RPM
OAT
FUEL FLOW
OIL PRESSURE
Yes, I confirm all this is in the system. And information about the height and temperature of EMS is received from the EFIS, but the system also has a GARMIN 696 connected to the serial port AP74.
And also the equipment was tested in flight, everything up to the operation of the autopilot functions perfectly.
Where is the OAT physically connected? IF the EMS, make sure that the EFIS OAT is set to N. If the EFIS (via the EDC), make sure that none of the EMS GP inputs are set to OAT. And after making sure of that, you may need to do a DSAB configuration. Also, are you able to display the EFIS screen on the EMS via the screen swapping/paging feature?
kulibin
Physically, the OAT connects to EFIS, I can display the EFIS screen in EMS via the swap / paging swap function, I checked the EMS GP inputs.
