In the release notes for v5.0 it states:
Improved: Modified percent power calculation for Lycoming and Continental engines to account for engine RPM red line, not compression ratio. When EMS > SETUP > GLOBAL > ENGINE TYPE is set to LY/CON, then the Tachometer HI RED/YEL parameter is factored into the percent power calculation. See: EMS > SETUP > SENSORS > TACHOMETER > HI RED/YEL.
I have an IO-320 which is rated at 160HP @ 2700rpm however I have a Sensenich prop which required a 2600rpm limit. Therefore I have 2600 set for HI RED/YEL. Will there be any change to the % power reading with the new firmware?
