We're not too familiar with the powerflarm devices ourselves, but the SkyView side of the configuration is can be found under SETUP MENU > SYSTEM SETUP > SERIAL PORT SETUP. Then you'll chose the serial port that you've physically wired the powerflarm. It's most likely to work with the FLARM format, but some flarm devices emulate TIS traffic format, so you may need to experiment there.
