vlittle
- Joined
- May 7, 2006
- Messages
- 551
After much gnashing of teeth, I installed a tray for the SV ADAHRS in the aft baggage compartment of my HRII. Before I close the skin, I need to route the wiring for the OAT probe, which will be located underneath the HS.
Since it will be impossible to route wiring when the fuselage is closed up, how can I obtain an OAT probe for prewiring? None of the Dynon docs show it as being available independent of the ADAHRS, and Spruce does not sell it as well.
It's actually possible to reach the probe through the aft deck access holes between the HS spars, so it's possible just to run wires from the ADAHRS location, then splice in another connector to a short pigtail of wires from probe itself and install it later. If this is acceptable, are there any special characteristics of the wire (number of wires, shield etc.)?
Thx, Vern
Thx, Vern
