Problem with the fuel flow indicator
JoanQuintana
Hi, I have installed a Dynon 180 in my new Virus SW Rotax 100HP, I have a problem with the fuel flow indicator is not resolved. It turns out that the indicator worked the first two hours (35 hours tine now use) and since then tells me 0.0l / h. The selle changed the flow meter, but consumption still tell me. Can you help me solve the problem?
If you've changed the sensor and the problem persists, then I'd suspect one of the three wires leading to the sensor. Confirm that the red wire does indeed have 12V on it, that black is ground, and that the white/yellow wire goes back to the proper pin as described in the Dynon Installation Guide
