Having trouble with my Ray Allen pitch trim interfaced with the SV-AP-Panel. Using the trim switch(s) mounted on the sticks, trim will run fine in either direction for appx 8 seconds and then quit. I can release the button and immediately reengage it and trim will then run again for about 8 seconds. It does that from full up to full down. I had initially hooked the trim up to the VPX-Sport and was able to configure it in the Dynon Skyview Classic. I could make it run continuously from full up to full down just fine and the trim indicator on the Skyview works fine. At that point I realized that I needed to change the motor wiring from the VPX over to the AP Panel in order to take advantage of the autotrim feature. I left the indicator wiring on the VPX and only moved the power for the motor and the trim switch(s) wiring to the AP panel as shown in the installation guide. The setup on the Skyview was performed and Autotrim function enabled. Same problem as described above. I tried changing amperage value to the trim from 2 amps to 5 amps. While running the trim motor the VPX configurator shows it only pulling .3 amps and no fault when it shuts down. Any ideas will be appreciated.
