problems with dynon efis 10
EGG
I have a dynon efis 10 and since a few days it switches on and off alternatively either on battery or main feed
can anyone help?
Does it restart as soon as it powers up? If so, a marginal power source can cause these sort of behavior (a very discharged aircraft battery), but it's also possible that some fault has developed with the unit. If you have the internal backup battery, try disconnecting it to see if that makes a difference.
Also, if you actually have an original EFIS-D10, note that we are usually unable to repair them due to lack of parts for the original model. They are also all long out of warranty at this point. However, we do offer a flat-rate upgrade in these cases which turns your EFIS-D10 into an EFIS-D10A, with a fresh 3 year warranty. See http://dynonavionics.com/docs/support_discontinued.html for details on this program.
EGG
thank you for your reply Ill check tomorrow if it is a d 10A or not, for info I bought it two or three years ago
EGG
My Dynon is a efis d10A s/n 005076 is there anything I can do?
We probably need to take a look at it here. Give us a call at 425-402-0433 or email support@dynonavionics.com to obtain a return authorization.
