jaredyates
I'm working up a custom servo installation and need to make pushrods. Thank you to Dynon for publishing the specs of your aluminum tube. Have you also published the specs of your rod end bearing? Is the oversized 1/4-28 thread chosen over a more readily available 10-32 because the strength is required? It seems like a big, heavy rod end, far bigger and heavier than the ones that are already used elsewhere in my control system.
This is thee closest match to the Dynon-supplied rod that I have been able to find so far:
https://www.mcmaster.com/#60645k812/=14wfri3
The photo looks a little different, but sometimes the photos on a big site like that are general.
Does Dynon sell the 100836-000 separately?
