How do I wire my D10A so that it can read the voltage on both batteries?
D dnhowald New Member Joined Aug 2, 2007 Messages 5 Aug 4, 2007 #1 How do I wire my D10A so that it can read the voltage on both batteries?
D dynonsupport Dynon Technical Support Staff member Joined Mar 23, 2005 Messages 13,226 Aug 4, 2007 #2 Re: Reading volts with dual battery electrical sys Wire your second battery to the Emergency Bus input on the D10A. Then use the voltage info item to display both.
D dnhowald New Member Joined Aug 2, 2007 Messages 5 Aug 5, 2007 #3 Re: Reading volts with dual battery electrical sys Which do you consider "Emergency Bus". I have Primary, Keep Alive and External Backup Power.
D dynonsupport Dynon Technical Support Staff member Joined Mar 23, 2005 Messages 13,226 Aug 5, 2007 #4 Re: Reading volts with dual battery electrical sys External backup.
