Reclock Servo Arm?
jnmeade
Eastern Iowa
I want my Dynon servo arm to be vertical. I made a mount for the servo and as it lays the arm is not vertical but off at a significant angle. Can I reclock the arm or do I have to remake the mount?
Marc_J._Zeitlin
Tehachapi, CA 93561
Grab the arm and turn the shaft until it points in the direction you want. You won't hurt the servo.
Maybe I'm not understanding what you're asking...
skysailor
The neutral position of a Dynon servo can be at any position. You may have to remove and re-install the servo travel limiting bracket to fit the new neutral position. Remember to verify full control deflection, and verify the servo cannot go over center when installing the limiting bracket.
What the above folks said is right - any spot around the rotation can be neutral, but you may need to adjust the servo limiting bracket.
