Red cube Sensor
Dw1oakes
Does the Red Cube flow sensor install before the Engine fuel pump or after the engine fuel pump?
Dave
Sportsman7064
Clinton, AR
I believe it should be mounted after the engine driven fuel pump, perferrably with minimal turns for a few inches either side of the cube, and have a continuous climb to the distribution servo on the engine (no low spots).
Russ
ttreat
why? the flow is the same before or after the pump. Mine works perfectly after the gascolator and before both pumps. The straight input and output are probably more important.
rfazio1951
I have a carb on my o-360 and I have the cube between the electric boost pump and the engine pump. Works perfect.
