Red X on the fuel pressure display
MGoodacre
Hi
Getting a red x on the fuel pressure display until the engine is running then working ok
Any suggestions pls
Mark
Mark, you should give us more info please, one liners are not helpful 😉
Which model SV system ?
What model, part number sensor do you have ?
Has it always had the same fault ?
if it’s a Kavlico sensor are you using an earth directly (can be paired) from the SV ?
Which software/ sensor files ?
GaryRay
Mark, check the ranges that were configured for the gauge set up to be sure it displays the zero value.
Changing the ranges won’t help here - it’s a setup/ connection issue.
mark hasn’t been in contact since his post so he probably figured it out - would be thoughtful if he posted that it is sorted🤔.
