I have a Rotax 912 ULS with the standard Skyview EMS settings. After initial avionics installation we noticed that oil pressure was all over the place and took it to a Rotax authorized service center. Their Dynon rep noticed that we had the wrong oil pressure transducer selected on the sensor map. Switched it over, and problem solved!
There are no issues around accuracy of pressure indication; however, I noticed that when the Skyview powers up (and before engine start) the oil pressure sensor has a red X over it, after which it functions normally. Interestingly, it is the only sensor that does this. The Dynon-trained tech said I should download the latest sensor config file, but that doesn't seem to have made any difference.
Any explanation on why this is so, and is there a fix?
