Replacement plug/pins (female) for battery backup?
kevineldredge
I am finishing my HDX install and seem to have lost the female side plug for two pin battery backup. I scanned store but am unable to fin parts number to reorder replacement plug? Ideas?
Used to be a Molex 43640-0301, but I think that may only apply to the older backup batteries (prior to HDX, and maybe even Skyview). There are lots of Molex options on Amazon, so you might be able to locate what you need there. You might want to buy it elsewhere, but Amazon appears to offer the best pictures to compare to your existing connector. Be advised, if you build your own harness, the cable should not be more than 24" in length.
kevineldredge
Thank you Bob, that was the ticket. Battery wires into HDX same as past versions. Also if you order them don't forget the special extractor
538-11-03-0043
11-03-0043
EXTRACTION TOOL
538-43031-0007
Pins
MALE 20-24 AWG BULK
