The EMS install instructions tell you how to wire the fuel senders.
If the calibration is done carefully your float fuel level indication will typically be within a gallon of actual. Here is how I do this:
- Replace your inline fuel filter with a temporary plastic "see through" filter from your favorite auto parts store. Install the filter before your electric boost pump. Route the fuel from this filter via temporary hose to a five gallon gas can.
- Get 20 gallons or so of 100LL. Fill one tank and flush it out using your fuel pump to the gas cans. Repeat this flush until you stop getting junk out of the tank. Repeat for the other side.
- Level the plane.
- With the gas tanks empty, follow the Dynon instructions for fuel level calibration adding one gallon at a time. If you have a typical install, the floats will work for the first 75% or so of the tank capacity, then will reach the end of their movement range. So if say this is 12 gallons, the readout on the Dynon will say "12+" until you burn down below 12 gallons, then it will read the actual tank level.
Carl
