Restricted Airspace display incomplete - R-2402C
clcarter144
The WindDancer, RV7 - N212S
On a recent cross country to OKC I encountered a (partial) display of the restricted airspace R-2402C adjacent to KFSM. Located on the east/southeast corner of the TRSA, ForeFlight displays, the correct boundaries, which are almost completely circular. On my Dynon Classic moving map it displays a semi-circle (see attached photo). This is a head scratcher. I've known of configuration settings that could cause this with MOA's but not restricted airspace, which should always display, in my thinking. Maybe I'm overlooking something. I'm going to the hanger tomorrow to double check settings but would entertain ideas or solution if someone else has encountered this before.
Many Thx,
Chris
ve0kog
does the airspace show when you pan the map?
airspaces can be shown or hidden based on two more filters.
First, SkyView will not display airspace sectors above the altitude chosen (in feet) in the
HIDE AIRSPACES ABOVE option. Second, SkyView will only show airspace sectors within the
chosen range (in feet) relative to the aircraft’s current altitude in the SHOW AIRSPACES WITHIN
option. For example, if the aircraft’s service ceiling is 20,000 ft, the HIDE AIRSPACES ABOVE
option would be set to 20,000 ft and would hide all airspace sectors above that altitude.
Second, if the aircraft is at 10,000 ft and the SHOW AIRSPACES WITHIN value is set to 3,000 ft,
ONLY airspace sectors that are between 7,000 ft and 13,000 ft will be displayed. To show all
airspaces, set both values to 99,999 ft.
the "missing" airspace starts at 13000 feet, may be it got decluttered?
