G3WGV
I've now bought a D120 and have been spending some time tinkering with the configuration. It has version 5.1.1 firmware, configured for the Roatx engine. One thing that caught my eye is the RETRN FLOW parameter in the Fuel flow section. The manual, somewhat enigmatically, states This function is generally used only by Original Equipment Manufacturers (OEMs).
I assume this parameter is to permit a fixed return flow constant to be set for fuel systems that have a low volume return to the tank, thereby obviating the need for a second flow sensor and differential counter. If so it would be most useful to know how this is set. Is there some algorithm based on forward vs. return flow volume, or is it more complex than that?
