reversed image on EMS
meacabuzz
My D100and D120 worked without failure during four months then since two or three flights when I power both EFIS, the D100 display is normal but the D120 shows a reversed image as you're looking at it in a mirror with small horizontal lines.Do you know this problem and what are the solutions?
All electrical connections are coming from Dynon and the battery voltage was 12,8 v.
Thank for your answers
That's a problem that will require service of the unit (it's an issue with the screen that we've seen a few cases of over the years). Give tech support a call at 425-402-0433 or email them at support@dynonavionics.com
dabear
Warrenton, Virginia
Would it be possible to get that reversed screen as an option? Just thinking about heads up display and with the bright screen that might work well.
DaBear
