roll adjustment
sachses
hi, installed the device slightly slant in the dashboard, as a result the instrument shows a small roll. I'ld like to adjust this to a correct even line. How is this roll adjustment been done? thanks
There is no way to adjust the EFIS's attitude indication to level when it is mounted with a slant. Also, if the EFIS is not mounted straight, the attitude, slip/skid ball, turn rate, and G-meter performance will suffer as well. In other words, the EFIS really needs to be mounted level with respect to roll (and yaw) to perform as advertised. The only adjustment possible is in pitch to accommodate panel tilt.
