ROTAX 912 . Oilpressure Honywell
Tomyfly
We installed a Honywell Oil Presseure Sensor ( diliv. from ROTAX) withe the Skyview. (Red pin 15 (12V) und white with Pin 6) in the Setup menue we chose the right type "Honywell Rotax)
HELP!! It does nt work!
It sounds as if you've done things correctly:
Sensor red wire to SV-EMS-220 37-pin connector Pin 15
Sensor white wire to SV-EMS-220 37-pin connector Pin 6
SETUP > EMS SETUP > SENSOR INPUT MAPPING > C37 P6 > PRESSURE + ROTAX OIL PRESSURE (HONEYWELL) + OIL
We've had reports from other customers of a fair number of problems with these Honeywell oil pressure sensors.
