Rotax 912 ULS/HDX EMS jumpy oil pressure & high fuel pressure
dlevy52
My EMS system is just a bit flaky. Very occasionally I will have the oil pressure jump around erratically. I've also noticed the fuel pressure to jump high occasionally. I don't know if they always occur together. On the last flight after landing and at idle both were acting up and I managed to get a video. Normally the oil pressure is rock steady and the fuel pressure in the middle of the green. I suspect neither is a bad transducer. Any suggestions? Is there commonality associated with these two readings?
GKC Aviation
I don't have Rotax diagrams, but for a Lycoming, the oil pressure, fuel pressure and manifold pressure all share the same 5 volt source and ground from the EMS, pins 18 and 17 of the sensor harness. Might be the same in your installation.
GDaddyT
Fly Navy!
KAVC South Hill VA
My oil pressure was jumpy, too. I suspected a loose connection, and sure enough it was! I secured the connector with some wire. On my 912ULS, the connection was underneath the oil filter.
