I am installing a 180 with a Rotax 912. When I go to the global settings and select Rotax as the engine type, the system configures the operating range for several of the monitored functions. On mine the tach is not correct. There are no numbers so I don't know exactly what they are but I have a narrow green band at the lower end of the rang and by the time I hit 4000 I getting a over rev warning. If I pick tachometer in the sensor settings it tells me it is using custom settings and cruise RPM is the only thing I can set.
I'm thinking it might be a problem between the seat and the buttons...
