RPM and MAP troubles on 912 is
Tuiliere
flying a RV7 in France.
FRANCE
Hi,
I am French, so, sorry for my approximative english.
I have a 912 Is with EMS 220/221 and two Skyview D1000.
Since 2 or 3 flights, the RPM and MAP widget have freeze frame (attitude)on the Skyview just after take off. I am obliged to push and pull my gas control lever two or more times before it works again.
Do you have an idea what's happened ?
Is it a probe trouble or a loose connection ?
Thank you for your help
Those pieces of information come from the Rotax ECU computer actually. We suspect that it might be stopping sending information momentarily. If you can get a diagnostic file from the SkyView display within an hour of when this happens, that would be helpful (SETUP MENU > SYSTEM SOFTWARE > EXPORT DYNON DIAGNOSTIC FILE). You'll want to do that when back on the ground because it does take some time to export to the USB stick. Let us know when you have it and we'll send you information on how to get it to us for analysis.
