damonmeyer1968
- Joined
- Jan 1, 2014
- Messages
- 6
1) My Skyview RPM display fluctuates wildly between the normal RPM and some much higher seemingly random RPM readings, rarely under 1000 RPM, but more frequently at higher power settings until it's almost continuous at cruise speeds. This is in a COZY III pusher application, with one mag and one LightSpeed EI. What are possible causes and solutions, and next steps to troubleshoot?
2) My Garmin 430 GPS is hooked up to the Skyview via the ARINC 429 interface. It almost always works when I first power up and start flying around - that is to say, when GPS 1 is selected on the Skyview, I get course guidance on the Skyview's HSI. However, it regularly fails after a few minutes of operation. I get a warning that the ARINC 429 is offline, and the Garmin 430 displays a message about the ARINC 429 failure as well. Then no more guidance. What are possible causes and solutions, and next steps to troubleshoot?
Thanks,
Damon
Thanks,
Damon
