RudiGreyling
Gents,
for the most portion of flight I have a stable RPM, with the exception of the full power take-off run 2650 RPM it jumps around a lot.
Standard 6 cylinder (IO-540) Lycoming with Mags, and SlickStart, 30K ohm resistor pickup on the P Lead.
I want to know about similiar experiences on same setup.
How have you solved it? Did you upgrade to the bigger resistor as discussed in the manual?
not keen to jump in behind the panel again
