RPM jumping up & down
Elmer
Hi, My Skyview RPM gauge won't hold still. It moves up and down 30 rpm. Anyone have an idea how I can get it to read the rpm without jumping around?
thanks
What kind of engine, ignition, prop, and RPM sensor do you have?
Elmer
My engine is the 110 HP Viking. The ignition is from the ECU.
It's the 3 blade Warp Drive prop. The RPM sensor is a wire out of the ECU and that wire is hooked to pin 32 of the EMS. Thanks for any help.
We don't have a lot of experience using the output from the Viking ECU. We don't generally have this issue with other ignition systems, so I don't know if it's just an issue with your install or the ECU in general.
1) Do other Viking users have any issues when hooked to EFIS systems? It could be that the output of the ECU does just vary.
2) Are you sure the prop is not actually changing speed?
3) You can try pin 34 on the EMS. You won't hurt this pin with the output from an ECU, but it might not work at all. Might fix it too.
