Hello,
I am running my Skyview installation (first D700, now HDX800) since about 10 years. Since some flights I have massive problems regarding displayed RPM's.
The problem is: Until 4400 RPM's the displayed RPM's are correct and smooth displayed, above 4400 RPM's the displayed RPM's are starts jumping up and down in the range of + 100...1000 RPM's or more or less. I did not see so often lower RPM's than the current RPM.
Off course the engine is running smooth and I let it run on constant RPM.
Every 2...3 second a wrong RPM is displayed than the current RPM is shortly shown and than some wrongs RPM's are displayed and so on...
Today I checked the cable and connectors and found no hardware problems.
According Skyview manual (SV-EMS-220/221 Rotax 912 ULS) I connected RPM to Pin 32 and the second line I conneted to Pin 5 (ground). And this worked for many years.
Now I am thinking about to disconnect the second line from pin 5 and connect it to pin 34 (low voltage rpm input left). In the pin mapping setup is configured for RPM pin 32/pin 34.
Who has any suggestions?
Thank you!
Best regards,
Harro
Thank you!
Best regards,
Harro
