Is the A200-HMS Hall effect transducer compatable with the Skyview EMS. It requires a 5 volt power source and ground. The output is a square wave. Is it producing a pulse or voltage? Which pins on the EMS are acceptable
If it produces a pulse relating to RPM, generally yes, it's compatible with a SkyView SV-EMS-220. Recommend using the low-voltage RPM inputs, Pins 34 and 35.
