Running power wires along with Dynon sensor wires.
melkel2000
Hi:
I have a Dynon D-180 and am presently running wires through the firewall. It seems the norm to have two holes in the firewall for passing wires through the firewall. One hole is for the thermocouple and sensor wires while the other one is for the stay alive power as well as BUS power (with a few other stray wires thrown in). Is there any reason why I can't put ALL wires through a single hole? I drilled a hole on the pilot's side and it's large enough the fit all the sensor wires as described above AND the power wires. Is there some interaction with the Dynon sensor wires I should avoid?
Re: Running power wires along with Dynon sensor wi
Not particularly. You should be able to pass them through together. If anything, we'd probably keep all of those wires away from any of the thicker current-carrying cables that go to/from the battery.
