704ch
Hey Guys, as you can see per photo, even though I built per spec, when my elevator is in the full up position the pushrod hits the roll servo arm fairly significantly. Any ideas, anyone else have this problem?
Per the instructions the servo arm is not 90 Degrees to the servo when the elevator is in neutral. If it were 90 degrees, that would potentially solve my problem. This would mean if I extend the servo pushrod about ½ inch it would center the servo when in neutral and the arm should be out of the way both up and down travel. i.e. in the photo, the servo arm would be pushed back further and lowered out of conflict with the elevator pushrod..
Would this do anything negative to the autopilot operation? It would be contrary to the Dynon Specs.
Link to photo: https://picasaweb.google.com/RV704CH/DropBox#5843039743890723874
