RV 9A Dynon Pitch servo install
compnz
New Zealand
Having installed the correct Dynon RV pitch kit as instructed, I have no clearance between the servo control arm and the elevator pushrod (RV part No F790).Is the solution to rotate the control arm 180 and have it swing under the servo rather than over?
It really doesn't matter which way you need to do it, just make sure you don't have a possible over centre situation at any stage of travel & you're good to go ;)
Jake J
compnz
New Zealand
Thanks Jake, I can see why you need to manage the over centre risk if there are no mechanical stops built into the servo. I will set mine up to run under and limit the throw to 60 Deg as recommended. Big Help
Patrick :)
