Screen layout
louie928
I purchased a Skyview 10". I intend to use it in my Zenith Zodiac 601XL. I've been reading over the user and installation manuals to get familiar with them. I had intended that I could configure the screen for EFIS, moving map, and EMS. All I see available for this is a 40%, 40%, 20% configuration with the divisions fixed along vertical lines. The displays end up in a long and narrow format. I cannot find a graphic in the manuals, or on the Dynon web site, to show what form the EMS indicators might be when in the 20% screen layout. Does anything like this exist? The Dynon site shows EMS at 50% and that looks fine, but what about 20%? Am I expecting too much? I searched this forum and didn't find information to answer my question. I was hoping for configuration flexibility similar to the MGL at http://www.mglavionics.com/html/odyssey.html. Click on the numbers 1 - 9 on the right side to cycle through some different configs available and there are even more mix and max choices.
Thanks.
meljordan
Tucson, AZ
You can configure any of the EMS screen layouts (100%, 50% or 20%) to whatever layout you wish. You select what widgets you want to be displayed, where on the layout you want to locate them and what style and size you want them to be. Obviously, the 20% screen can not display as many widgets as the larger ones, but it is pretty easy to set it up for the info you feel works best for you. This solution is much more flexible than anything else on the market, as it is totally customizable.
Best Regards,
Mel Jordan
