SCREENSHOT MISSING EXT DRIVE
PeterBain
i keep getting this error message when i try and take the snapshot :'(
Then this is what it looked like when i downloaded.
Obviously the memory stick is connected
Try waiting a little longer after plugging in the stick before pressing the buttons the first time. Also, you might just try a different memory stick.
preid
SoCal
Shouldn't make a difference. Try a different stick.
I have had issues with my Dynon sticks as well. I ended up using a Replacement 2gb stick and it has worked without issue
I have found that some of the earlier (mostly white colour with Dynon logo) 'sticks' have a problem in that the 'tongue' partly retracts into the body due to it coming unglued internally.  Squeezing the body (flat sides), between two fingers,  at the insert end while inserting prevents that from occurring.  Or you could prise it open and re glue the board onto the shell  ;)
Jake J
PeterBain
Bought a new one.
Cheap enough.
One thing to consider is when you format the stick check whether it is FAT 32 or the other format.
I can only get FAT32 but i know some of the others have both.
Havent checked whether the skyview stick has options.
