- Joined
- Mar 23, 2005
- Messages
- 13,226
For those of you that are running 2.5 on your SkyView systems, we had a bug with our website that meant the downloaded Sensor file was not as up to date as possible. When convenient, please update to the current one. This is not a safety of flight issue.
Issues with previous file:
1) On the fuel computer add fuel page, the “measured fuel” level can be jumpy
2) Small negative values are seen on the ground for pressure sensors in some zero PSI situations
3) The GRT oil temperature sensor is WAY off.
File can be found here: http://dynonavionics.com/docs/support_software_SkyView_sensor.php
