I've just run my RV-7's engine for the first time and a few sensors aren't talking to the FlightDek 180. The oil pressure was showing, but has now stopped. The manifold pressure isn't showing, the amps (with a GRT hall effect sensor) are jumping about all over the place. Also, when I tried to calibrate the fuel levels (capacitance senders) the sensor values don't change as fuel is added. Lastly, the trim position isn't showing on the EFIS pages.
Lots of questions. How do I go about fault finding the above snags? Oil temp, fuel pressure, rpm and everything else is fine.
