We understand the confusion - the DB9 connectors that SkyView uses as SkyView Network are much more commonly used on PCs as "RS-232 serial". However, on SkyView, the DB9 connectors on the SkyView displays, and most SkyView modules, are NOT "RS-232 serial". Thus any cable that is intended for "RS-232 serial" should probably not be used.
Some major differences between SkyView Network cables and "RS-232 serial" cables:
[list bull-blackball][*]"RS-232 serial" cables often don't include all wires / pins, often only Pins 2, 3, and 5.
[*]As Tom Thibault pointed out, "RS-232 serial" cables are often not wired pin-to-pin, as SkyView Network requires.
[*]SkyView Network carries power, and depending on the specific cable (location in the SkyView network), substantial enough power to cause an "RS-232 serial" cable to fail.
[*]Because of the high data rate, a SkyView Network cable has the two data pairs twisted together in a specific, repeated pattern (8-10 twists per foot), "RS-232 serial" cables do not have this twist.
[*]"RS-232 serial cables" are usually manufactured inexpensively; SkyView Network cables have all conductors specified as 22 AWG.
[*]SkyView Network cables, as manufactured by Dynon Avionics, are made of wires with Tefzel insulation and jacket; if they're exposed to fire, the resulting smoke is non-toxic.
[/list] Thus... don't use "RS-232 serial" cables in your SkyView system.
If you're lucky, your "RS-232 serial" Null Modem cable just swapped Pins 2 and 3, which are both ground in SkyView Network and there won't be any damage to the module. If you're unlucky, your particular "RS-232 serial" Null Modem cable may include pins in addition to 2, 3, and 5 and thus may have damaged the module that you connected using this cable. It depends on how that particular cable was wired. If so, the "RS-232 serial" cable connected power from the SkyView display to a pin on the module that was intended for data. If this happened, unfortunately it's not covered under warranty - contact Dynon Avionics Technical Support to arrange for a Return Material Authorization (RMA) - 425-402-0433 or support AT dynonavionics DOT com.
Dynon Avionics offers a 1.5 foot SkyView Network cable - SV-NET-1.5CC - contact Dynon Avionics Sales or any Dynon Avionics dealer to purchase.
I wanted to shorten the serial cables from my Dynon EFIS screens reduce the bulk of the connections. I ordered a 1tf serial cable DB9 female to female and they don't work. What does null modem mean and does that change the pinout of the cables
