Serial I/O femal D9 plugs, which ones will be used
Groundloup
I have wired my panel with your harnesses for a D-180, HS34,AP74 and D-100. I have 2 female D9 plugs from the D-180, one to input software and one to retrieve data. I also have a female D9 plug from the HS34 and one from the D100. Will I need these last 2 D9 plugs to input software or are these not used with all the devices wired together through the DSAB system?
Re: Serial I/O femal D9 plugs, which ones will be
You need all of them to do software updates.
PhantomPholly
Another option is to buy a rotary 2-pole switch, feed all of the serial lines to discreet positions on the switch and have a single 9-pin dongle. You then simply select which function you are performing (EFIS update; HS34 update; Data logging) before firing up the software.
