Servo detection
gwill
I´m installing the pitch servo (SV32) and want to configurate with the two skyview sv-1000 displays.
They couldn´t detect the servo.
The wires are connected correctly , the servo power is on
and the disengage button is open.
Firmware is 6.0
Any suggestions?
Unless the servo has been electrically damaged, this is a good chance that something in the wiring isn't right. When you say you're trying to configure, you're starting with SYSTEM SETUP > NETWORK SETUP > CONFIGURE..., correct?
gwill
I´ve installed the second servo. I don´t use the sv-net-servo wire because I use four pins (1,4,6,8) of the DB9 servo connector. When I run a network configuration , he finds five items:-EMS,SVD1000(1),SVD1000(2), ADAHRS 200 and 201 but no servo´s. I bought the servo´s (SV32) in 03/09/09.
Is it possible that I use the wrong software (6.0).
Relax Gerry, I think the date of the servo is the clue to the issues you're having - I'm sure DS will chip in here ;)
Jake J
Yes, those servos were shipped before SkyView even existed, so the software in them is not compatible. You will either need to connect them to a Dynon D100 and update the software, or mail them to us for an update.
Please give us a call or send an email to support so we can help you out further.
