This is a new build of a Van's RV-12. The build was started as a D-180 and therefore has the Van's Skyview conversion harness.
The AP servos were not detected by 'Config | Detect' under Skyview version 5.5, so an upgrade to v 11 was performed.
The attached image shows the current state of the 'Config | Detect'.
Also of note: if the servos are powered up via the Autopilot switch, the Skyview will not complete its boot-up operation - it sticks at 'Enumerating Network' or something of that nature. Attempts to re-apply the version 11 update also fail on the same way.
The wiring to the servos has been re-examined a number of times - all wire-to-wire colors match the Van's plans.
Edit: after looking through some other "missing servo" issues here on the support forum, it appears that only one of the two servos is appearing in the list. I'm not sure if this means there are actually two problems, or if these symptoms indicate only a problem with the missing servo.
