Setting the ADS-B in Frequency
B
BigFlapper
I'm trying to setup the transponder module with my skyview unit and I'm at the ADS-B in frequency. I don't have the SV-ADSB-470 unit. What selection do I use? NONE, 978 Mhz, 1090 Mhz??
Tom
You would use NONE in that case since you aircraft has no ADS-B in capability.
johnsteichen
So, if you do have the Dynon ADSb and the Dynon transponder, what do you set in the ADS-b frequency?
If you have them both installed, it sets it automatically and tells you you can't change it. So the answer is: Who Cares! ;)
